D16Y7 knock sensor
Old Sep 7, 2012 | 06:17 AM
gogolf0401's Avatar
Default D16Y7 knock sensor
Hi Guys. I recently bought a 96 EX coupe. Apparently the previous owner swapped the Y8 for a Y7, but it appears he kept the VTEC head off the Y8 because I'm pretty sure I'm staring at the VTEC solenoid. This must also mean he kept the Y8 ECM.. The only code I am getting is a knock sensor code, which makes sense since the connector for it is just swinging below the engine. Pretty sure this is because the Y7 doesn't use a knock sensor, nor have a place to screw it in. I'd like to know when a legit code comes up, but I won't be able to tell if it is always on because of the knock sensor...
Anyone know if there is a way to drill/tapp the Y7 block for a knock sensor?
Thanks
Old Sep 7, 2012 | 12:06 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: D16Y7 knock sensor
It has a threaded hole for the knock sensor, the blocks are identical and have the same Honda part number P2E-810
Old Sep 28, 2012 | 08:43 AM
gogolf0401's Avatar
Wow. You are right! I bought a knock sensor off ebay for $11 and screwed it right in the Y7 block. Now my codes are clear! Thanks!
john'sD16Aek
15
May 1, 2013 02:25 PM
98greensi
Aug 11, 2010 10:00 AM
tobe1424
Feb 26, 2006 09:41 AM
theeogflip
37
Jun 21, 2005 05:04 AM
EK_vzla
Feb 3, 2004 06:32 AM
