Garage Cleanout (Dc2 , EG , and B series mostly)
Prices are best offer obo.......
1.) Brembo Blank Rotors (fits integra or civic with 4x100) *BNIB **SOLD**
2.) Hawk HPS Brake Pads (fits integra caliper) *BNIB
3.) Duralast Gold Brake Pads (also for integra calipers) *BNIB
4.) JDM ITR Header (replica, fits any b series) *comes with custom test pipe **SOLD**
5.) DC2 Brake Master Cyl (ABS)
6.) DC2 SRS Unit (with wires and fuse box)
7.) Integra Brake Conversion (EVERYTHING NEEDED)
-front hubs with calipers, rotors, even some used pads
-DC2 front upper control arms
-rear trailing arm, calipers, rotors, e-brake cable **SOLD**
8.) DC2 ABS System with all lines
9.) DC2 Clutch Line (oem hardline from master cyl)
10.) DC2 Throttle Body (came from 94 gsr)
11.) RS Machine ITR Spec Pistons on Shotpeened LS Rods w/ ARP Rod Bolts (Used about 10k)
12.) B18 Block w/ Crank, Main Caps, and good used acl main bearings, windage tray, oil pan
13.) Civic 92-95 Front seats (rip on driver side bolster)
14.) DC2 Rear Coupe Seats Gray (mint)
15.) Mishimoto Full Size Rad (for DC2) **Will trade for ½ sized rad + cash
16.) DC2 Front/Rear OEM Sway Bars (with bushings) **SOLD**
17.) 92-95 Civic EG Passenger Headlight
18.) DC2 Rad hoses (Used but still fine)
19.) 92-95 Civic EG Manual Steering Rack (NEVER USED.. comes with new tie rods also)
20.) RSX oem Shocks and No Name Lowering Springs (Used for a good while. . . CHEAP)
21.) 92-95 EG Manual Cluster (no tach though)
22.) DC2 Carbon Fiber Tail Lights
23.) Turbonetics T3/TO4E Big Shaft Turbo (Taken apart and ready for rebuild, all parts are mint)
24.) Integra GSR Cams and Cam Gears **SOLD**
25.) Ebay ½ Sized Rad (I used it for a while before mishimoto, works good)
26.) Distributor (OBD2 GSR Vtec, was told it was 'rebuilt', looks to be) **SOLD**
27.) Distributor (OBD1 D16Z6, no cap or rotor)
28.) MSD Modified Distributor Cap (PN82933, 94-01 GSR)
29.) DC2 Torque Mount
30.) DC2 Clear Corner Marker Signals
31.) OBD1 Alternator (B Series)
32.) 4 Different T Brackets (not sure for what car they belong but just ask ill find out if needed) **3 LEFT**
33.) Greddy RS Blow Off Valve (replica, painted back, def works too)
34.) Idle Air Control Valve (All B-Series I believe) **SOLD**
35.) 92-95 civic ashtray/lighter bezel
36.) B-Series Clutch Cover
37.) Professional Products Fuel Rail w/ OBX FPR (black, b-series) **SOLD**
Feel free to call/text whenever 484-368-1978
- Jared
- Jared
function83
Northwest (Sales)
Apr 6, 2008 11:10 AM
