Is it hard to install a rear lower tie bar??? HELP!!
Old Oct 16, 2002 | 04:36 PM
TurboTurtleGSR's Avatar
Default Is it hard to install a rear lower tie bar??? HELP!!
Has anyone installed their rear lower tie bar? What steps do I need to take to do this? I want to install my Spoon Rear Lower Tie Bar. Will I need jackstands? Is it hard to unbolt the lower control arms and rebolt them again? Please help!
Old Oct 16, 2002 | 05:07 PM
Fuuma0083's Avatar
Default Re: Is it hard to install a rear lower tie bar??? HELP!! (TurboTurtleGSR)
you need to jack your car up and put them on jack stands.
Old Oct 16, 2002 | 05:09 PM
-Gambit-'s Avatar
Default Re: Is it hard to install a rear lower tie bar??? HELP!! (Fuuma0083)
yes you will need a jack and some stands, all you have to do is take out 2 screws and its in there, it will take you longet to jack up your car then it will to put the bar on.
Old Oct 16, 2002 | 05:19 PM
The_Oz's Avatar
This will give you a rough idea of what you're about to do:
http://www.g2ic.com/tegtips/suspension/1.html
Pictures shown are from a G2 Integra.
Regards,
Oz
Old Oct 16, 2002 | 05:22 PM
Bigjussin's Avatar
Will a lower Tie Bar for a 96-00 civic fit? I know some parts can be swapped, is this one of them?
thanks
Old Oct 16, 2002 | 06:42 PM
Isaac's Avatar
New User
Default Re: Is it hard to install a rear lower tie bar??? HELP!! (bigjussin)
thanks
I believe not, it's generally EG's and DC2's that share the same chasis parts.
Old Oct 16, 2002 | 06:49 PM
Default Re: Is it hard to install a rear lower tie bar??? HELP!! (gambit33)
Do I need to remove the rear wheels? Does the lower control arm are stay in place when the bolt is removed or will I have to line up the lower control arm when I put the bolt back in?
Old Oct 16, 2002 | 07:09 PM
-Gambit-'s Avatar
no you wont have to take off any wheels
Old Oct 16, 2002 | 07:10 PM
Dirty GS-R's Avatar
New User
That's the part that can be a little tricky.
Old Oct 16, 2002 | 07:14 PM
KOALA YUMMIES's Avatar
You WILL want to remove the rear wheels. It will lighten the load on the control arms and make it easier to maipulate the bolt. The Skunk 2 ones use different bolts, which differ from the tapered factory bolt. Not sure about the Spoon ones, but removing the wheels will ease the installation.
Old Oct 16, 2002 | 07:29 PM
Dan GSR's Avatar
did your spoon bars come with hardware to replace the stock LCA bolts?
Old Oct 16, 2002 | 08:13 PM
Default Re: Is it hard to install a rear lower tie bar??? HELP!! (Dan GSR)
Nope, you just bolt it behind the factory LCA bolts.
Old Oct 16, 2002 | 08:15 PM
Default Re: Is it hard to install a rear lower tie bar??? HELP!! (Dirty GS-R)
What is so tricky about this?
Old Oct 16, 2002 | 08:28 PM
-Gambit-'s Avatar
its just tricky sometimes because your control arm will move just a little bit, so you have to get the holes lined up again, not really that big of a deal
Old Oct 16, 2002 | 10:21 PM
GSRrR's Avatar
I could not get the bolt back it without lowering the car till the rear wheel touched the ground. The holes will just not line up. I tried for 40 minutes then decided to lower the can and it went in in 5 minutes. If you need and more help just message me. HTH
Old Oct 17, 2002 | 07:24 AM
Tstec85's Avatar
Not at all it took me 30 mins on my driveway with a honda Jack, lol.
It prob wasn't the safest way but it worked just fine for me. As long as the car does not shift, the lower tie arm bolts will go in and out with out a problem.
Old Oct 17, 2002 | 08:54 AM
fubar's Avatar
Default Re: Is it hard to install a rear lower tie bar??? HELP!! (Tstec85)
I found that using your jack and placing it underneath the control arm and raising it up a bit helps to make aligning the holes easier.
Good luck!
Old Oct 17, 2002 | 11:13 AM
DC2_Integra's Avatar
removing those bolts on the control arms, does it affect alignment?
Old Oct 17, 2002 | 11:33 AM
IntegraGSR23's Avatar
Default Re: Is it hard to install a rear lower tie bar??? HELP!! (DC2_Integra)
Not really hard at all. I have installed and removed mine a couple of times and some friends and was not all that complicated.
If anyone is interested I am selling a DC Sports Rear Lower Tie Bar - Silver finish
Model Number: HTB3003
Fitment: 90-00 Integra
88-95 Civic
93-97 Del Sol
Asking $70 shipped O.B.O.
[Modified by IntegraGSR23, 12:45 PM 11/7/2002]
Old Nov 7, 2002 | 11:39 AM
asianautica's Avatar
It's funny that you said that because I had the same problem last night when i was trying to put on my spoon tie bar. The control arm moved and it took me 2 hours just to put back the bolt. I end up have to lower my car to get it lined up again. So right now, the tie bar is still off because i'm too affraid of taking it off again.
dth0ng69
Suspension & Brakes
Dec 11, 2009 11:37 AM
joethejoeman
Feb 22, 2007 10:00 AM
IntegraPrez
Oct 19, 2004 08:22 PM
dLo GSR-stolen-now-WRX
Jun 19, 2002 11:55 AM
