HELP!!! 95 civic non abs conversion
Old Sep 6, 2012 | 07:23 AM
WillyD's Avatar
Icon3 HELP!!! 95 civic non abs conversion
If anyone has info on this conversion please let me know
What prop valve do I use and from what year can I get it from
Old Sep 6, 2012 | 09:38 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: HELP!!! 95 civic non abs conversion
What are you trying to do???? Get rid of ABS or add it? You need to supply more info if people are going to be able to help!
Old Sep 6, 2012 | 09:43 AM
WillyD's Avatar
I'm trying to remove it.. Sorry
I just need to know if this is possible and what parts I would need. It had abs but the unit fucked up so I decided to remove it. I do have rear disc brake on my coupe
Old Sep 6, 2012 | 10:16 AM
dirty19's Avatar
Ridin Dirty in Cali
A 40/40 prop valve from an integra gsr or 2000 civic si should work.
Old Sep 6, 2012 | 11:14 AM
kyden's Avatar
no. a gsr has abs so there is no prop valve. a 2000 si prop valve won't bolt up.
92-95 non-abs civic or 94-97 integra rs lines from the master to the valve, then the valve that corresponds to your current braking system.
Old Sep 6, 2012 | 12:02 PM
WillyD's Avatar
Ok so if I have discs front and rear what do I need?
Old Sep 6, 2012 | 12:50 PM
dirty19's Avatar
Ridin Dirty in Cali
ooooooooooooo yea this is true.... thanks for clarifying that.. my race car has a rs lines.
Old Sep 6, 2012 | 01:19 PM
WillyD's Avatar
Besides the prop valve what else do I need..?
I have already removed all abs lines and abs system... I cut the lines going to
The back wheel at the fire wall, I can just add a fitting to connect the rear lines there
Do I have to change mc or booster
megatoninduk
Jun 13, 2010 02:36 PM
young geezer
Sep 29, 2007 04:55 PM
psegs80
10
Sep 15, 2007 09:17 AM
brick96EX
May 4, 2004 07:57 PM
