Thanks from a Lurker :)
Just wanted to give a big thanks to you guys in this forum who are putting in hours here writing up things that you have experienced when wrenching on your Accords.
From the huge awesome write-ups (Timing Belt, Valve Adjustment, FITV Cleaning...) to the comments on what problems you faced while following the write-ups.
Great stuff all around
Just finished the first time doing any of the following on my 91 Accord Wagon (5speed) and most of it thanks to info provided on this site!
Timing Belt
Balancer Belt
PS Belt
Alternator Belt
Water Pump
Cam/Crank/Balancer Seals
Valve Cover Gasket
Oil Pan Gasket
Distributor
Plug Well Seals (under Rocker)
Valve Adjustment
IACV/FITV Clean
Crush Gasket on Downpipe
Lots of frustration/time saved by following info provided here.
Just wanted to take the time to say thanks and hopefully I can contribute a bit with some of the things I found when doing the above.
Timing Belt
Balancer Belt
PS Belt
Alternator Belt
Water Pump
Valve Cover Gasket
Oil Pan Gasket
Distributor
Valve Adjustment
IACV/FITV Clean
It's nice to see someone taking advantage of the FAQ/archived threads.
Glad to see that you were able to save yourself some cash and have some fun wrenching on your car. It's pretty satisfying when it's all said and done!
Mike VR6
35
Mar 2, 2007 03:23 AM
Ideal
Jul 18, 2002 09:46 PM
