Would this RSX relay setup work with an EM1..??
Old Sep 5, 2012 | 04:17 PM
JDM_SOHC's Avatar
Default Would this RSX relay setup work with an EM1..??
Ok so when I bought my car it came with Foglights already installed and a foglight switch, but that's it, no harnesses in between the two, and no power source of any sort... Well I wanted to wire them to come on with my parking lights and found a great write up on how to do it here http://forums.clubrsx.com/showthread.php?t=584514 but that's for an RSX and I'm not sure if it's the same thing for an EM1...
Here's my switch that I currently have...
And I just went and bought an inline fuse, relay, wire, spade connectors, heat shrink, and also some D-SUB Connector PIN's so I can PIN into that switch if somebody does know the exact PIN layout..
So basically what would be easier for me to do, wire directly to the parking lights with a DIY relay setup all under the hood, or use the switch and instead use the relay for an under dash relay setup..??
JLEK
Audio / Security / Video
16
Apr 13, 2007 05:59 AM
Joon Joon
27
Oct 23, 2005 05:49 PM
4DRmafia
Sep 14, 2004 07:45 PM
integra99blue
Aug 16, 2001 09:49 PM
