looked at faq, how do i get code for p28 while car is running
ok my car gets a code when i am coasting in gear. this code goes away when i shut the car off. i looked in the faq and it says how to read the code by having the car off and then turning the key to the II position. just curious how to read it while the car is running please help its a dd
Tip #3: My CEL turns on while driving but I can't pull any codes?
In some cases, the CEL of 5th generation Civics (92-95) may turn on while driving, but if the engine is turned off, the CEL and CEL code will be lost. The workaround to allow recovery of the code when this happens is to safely pull to the side of the road and leave the engine running while you jump the service connector.
dubnine
Jun 1, 2007 07:00 AM
eg crunkmonster
Jan 14, 2004 03:29 AM
