ls vtec on 99 ek sedan
Old Sep 5, 2012 | 12:28 AM
Jdm_kidd808's Avatar
Default ls vtec on 99 ek sedan
i know this is a noob question to all you guys and this is my first actual post on this website..
so here im doing an ls vtec swap into my 99 ek sedan, i will be using an 5spd ex harness and i was wondering what time of distributor should i use??
a friend of mine said gsr 00-01. but i wanted to make sure just incase when i do the swap i wont messed up.
if anybody knows which distributor i should use and can i get the parts # also??
thanks.
Old Sep 5, 2012 | 12:52 AM
jbpnoman's Avatar
Default Re: ls vtec on 99 ek sedan
Use the distributor that matches your head. If you're using a GSR head, use a GSR dizzy. If you're using a SI head, use an SI dizzy. For simplicity, I would use a dizzy that matches your harness.
Old Sep 5, 2012 | 01:22 AM
greenteadude's Avatar
any of these will fit on vtec head obd2
part #'s TD81U, TD84, TD84U, TD86U, TD87U,
Old Sep 5, 2012 | 01:24 AM
HondaPartsHero's Avatar
Technical Hero
None of those will plug and play. You can use any OBD1/2 B series VTEC distributor with the appropriate adapter.
Old Sep 5, 2012 | 07:46 AM
i am currently using an ex 5spd harness 99-00
04silvep3
Dec 21, 2008 07:35 PM
jeremy.
Dec 19, 2003 07:40 AM
I 8 1 U 8 1 2
Sep 17, 2003 01:08 PM
Reddog
Jun 27, 2002 12:07 AM
