Eg dash light dont turn on need help
Ok so my eg dash light stop working few weeks ago i checked the fuses, and even changed the cluster and its still the same. Everything works rpm, speed, gas etc even the turning signals and every other components. Just the lightg dont light up. Any suggestions on why might be? Tips on what to change?
Did you check the cluster light switch on the left side of your steering wheel? Little turning ****.
If that doesn't work, trace the wire from cluster to the fuse box. See if there's continuity. Easy to check. Put a DMM between the back of the cluster and fuse.
Also check the cluster ground.
I had same issue with my eg I replaced the dimmer switch and that fixed it for a while but after a while they started flickering it turned out to be the headlight switch on the column. Now if I wiggle it they will come on. Good luck
h22carpetride
Jul 14, 2010 06:44 PM
civicDX2178
11
Jul 25, 2006 07:44 PM
alispoon
13
Feb 27, 2006 09:09 AM
