Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
no brake lights
Old Sep 4, 2012 | 02:11 PM
Herb Gentle's Avatar
Default no brake lights
tried installing aftermarket 3rd brake light on 06 accord ex sedan. now i have no brake lights at all. Tail lights still work. Replaced brake light relay on brake pedal....still no joy! Any suggestions?
Old Sep 4, 2012 | 06:15 PM
lazlong's Avatar
Default Re: no brake lights
Can you be a little clearer? Are you replacing the original 3rd brake light or putting in a new one? Are you replacing a regular bulb with LEDs? Where and what did you cut/splice exactly? Pics help a lot.
Old Sep 5, 2012 | 04:09 PM
afesposi's Avatar
I am a HondaTech sponsor and I sell LEDs on here with free shipping and they are all plug and play!! They look SO good in brake lights!!
Old Sep 11, 2012 | 04:11 AM
a1alimo's Avatar
I can't understand your question clearly but , i think yours car break light is not working right.nowadays there are lots Of LED lights available in market , instead assembling by yourself take it to workshop and solve your Work.
Old Sep 11, 2012 | 06:09 AM
Steve@Spreen's Avatar
If the a/m light is a plug-n-play, there should be no wiring issues. If you had to cut and splice wires to install this 3rd Brake light, then there is probably a problem with the wiring. Recheck your wires, connections and make sure nothing is grounding out. Check your relay/fuses also. HTH
Old Aug 15, 2021 | 01:00 AM
RonaRoo's Avatar
My 93 Honda Accord has no break lights, or putting in the fuse break lights are on constantly even when the car is off. So I don't have the fuse in at all. I'm at a standstill with it probably a wiring problems. I'm ready to give up on this "Speedy" brake problems. Got a quote from a specialist they said $1200.50, another mechanic said $500 (w/o knowing the whole dealio) & another mechanic said $800, not counting the "lights" problem... The Accord needs brake pads, rotors, & calipers. Plus lights not working. I am NOT mechanically inclined (like my sister, brother, uncle or friend) to do it myself. 😩
I'm at least gonna take it to a different repair shop to get the lights fixed...
delgato
Jan 12, 2021 07:27 AM
Peepers
Honda Civic (2001 - 2005)
May 23, 2012 05:16 PM
keywest407
Feb 14, 2012 11:29 AM
disboiflaco
Mar 14, 2011 05:45 PM
AndyD
Feb 18, 2008 11:09 PM
