MISHIMOTO Radiators, Shrouds, Hoses,COMBO DEALS, FREE SHIPPING!!
Hi, Logic Motorsports is now offering Mishimoto radiators at UNBEATABLE PRICES and FREE SHIPPING!!
PM FOR BEST PRICING!!!
ASK ABOUT COMBO PRICES!!!
**Whether you take your car to the track or use it as a daily driver, an upgraded cooling system is essential in maintaining a well balanced efficiently running engine. The Mishimoto performance aluminum radiator is the ideal upgrade to the stock radiator especially for those looking to enhance the overall performance and lifetime of their engine. With a direct OEM fit installation is effortless, no cutting or modification is required. All Mishimoto Integra radiators are designed and engineered to maximize cooling efficiency and most importantly protect your car from overheating.**
**Mishimoto radiator hose kits are made with a dual layer combining high grade silicone and heat-resistant embedded fibers to provide efficient heat reduction and increased pressure tolerance, all with designed and engineered for a direct OEM fit. The perfect replacement for a stock hose kits.**
-ALL HOSES AVAILABLE IN BLACK, RED, OR BLUE!
**The Mishimoto aluminum fan shroud kit will considerably improve engine cooling functions and the overall performance of your vehicle. All Mishimoto fan shrouds are significantly lighter than standard fan shrouds. The longevity of your engine depends on keeping your engine running cool, especially during those unbearably hot days. A Mishimoto fan shroud will notably improve engine cooling performance by delivering more air to the aluminum radiator and driving out excess heat. The fan shroud serves another very important purpose: It secures the fan blades, preventing potential damage to other essential engine components.**
**The Mishimoto racing thermostat will promote greater cooling efficiency throughout your engine. The Mishimoto racing thermostat will significantly decrease high engine temperature resulting from modified and upgraded turbo applications. Once the engine is fully warmed up, the Mishimoto racing thermostat will open up at a lower temperature than standard thermostats (78º C). This allows the coolant to flow through the engine sooner, thus reducing and maintaining cooler engine temperatures.**
Thanks,
Devin@Logic Motorsports
Thanks,
