YCP or Nippon Cast Piston Dealers?
Old Sep 4, 2012 | 12:03 PM
Nisif's Avatar
Default YCP or Nippon Cast Piston Dealers?
I'm looking to purchase a set of 81.5mm aftermarket cast pistons for turbo b18a ls build. Any of you know a place that sells them other than on ebay?? One of the ebay vendors (that sells nippons) lists the compression ratio incorrectly on their ad. I'd rather talk to a store that is more knowledgeable and see if they are offered in different compression ratios, etc.
So far these are the only 2 I've found (both on ebay).
YCP:
http://www.ebay.com/itm/YCP-Honda-Ci...7dbfba&vxp=mtr
Nippon:
http://www.ebay.com/itm/Nippon-Racin...f853c2&vxp=mtr
Old Sep 4, 2012 | 12:53 PM
Muckman's Avatar
Moderator in Chief
Default Re: YCP or Nippon Cast Piston Dealers?
2 things - cast pistons are terrible for high heat / forced induction. And if you get get the dome/dish volume of the piston you can calculate the actual compression.
Old Sep 4, 2012 | 03:51 PM
Ben Huynh's Avatar
I don't recommend them but we do carry the Nippon pistons and rings.
Old Sep 4, 2012 | 04:28 PM
EsotericImage's Avatar
Retired Moderator
I agree but if the car is gong to see boost here and there and mostly driven on the street then cast will be fine..
On the strip where boost will be full on is another story. Forged will be best.
Old Sep 4, 2012 | 04:55 PM
v8killaz's Avatar
local guy making about 500whp on the nippon and im currently on ycp vitara 24psi daily driver, beat and boosted every day of its life
that tune will determine reliability
Old Sep 4, 2012 | 05:04 PM
turbo82's Avatar
Tell that to speedfactory lol.
Old Sep 4, 2012 | 05:17 PM
Nisif's Avatar
How whp are you laying down on 24psi? And how many miles have you put on this setup?
Old Sep 4, 2012 | 05:30 PM
Nisif's Avatar
I'd rather go with forged, although I've seen pretty good results with the aftermarket cast. A lot of the online vendors don't have the dome/dish volume otherwise I'd calculate it. Speaking of...
Here's an online calculator that I found but I don't think it's accurate. I put in specs for a stock b18a and it calculated the compression to 9.6:1. I was pretty sure stock b18a engines were 8.8:1. Any better calculators out there?
LINK: http://www.zealautowerks.com/bseries.html
Pm'd...do you what c/r is offered in 81.5mm for a b18a?
Thats one of the many threads that I've heard good reviews about them. A number of 400whp builds using nippon cast pistons...
Old Sep 5, 2012 | 10:56 AM
lsturbo33's Avatar
400whp here from the white box nippons. I put the motor together early 2011 for my dd. Bottom end has 15k on it. The next motor I put together will be forged though just for peace of mind.
Old Sep 8, 2012 | 04:50 PM
v8killaz's Avatar
no idea. street tune myself. no real tuners around the area so have to do without. id say somewhere around 300whp though. i put about 10k on it. but those are hard miles with 140mph+ pulls in 5th gear
Old Sep 9, 2012 | 05:31 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
This thread is like comparing trash to garbage. If I HAD to choose (with a gun to my head) I would probably pick YCP's because you can find them coated on the eBay site.
TheCrimsonGhost666
Dec 8, 2010 11:42 PM
Charlie Moua
Nov 29, 2009 08:56 AM
rohec04
Apr 21, 2006 08:40 PM
riceball777
Mar 1, 2006 05:04 PM
riceball777
Feb 20, 2006 02:36 PM
