removing rocker assembly
Old Sep 4, 2012 | 11:30 AM
wasp9166's Avatar
Default removing rocker assembly
i was watching the video in this thread
http://www.cb7tuner.com/vbb/showthre...lug+tube+seals
2 questions
can the assembly be removed in any position or does the motor have to be at tdc?
and nothing popped up like the poster was saying due to belt tension when he removed it..........so what exactly is the op talking about?
Old Sep 4, 2012 | 05:14 PM
Former User's Avatar
Default Re: removing rocker assembly
Please state your car and engine when you post in tech forums.
Old Sep 5, 2012 | 04:26 AM
wasp9166's Avatar
91 civic dx
d15b
Old Sep 5, 2012 | 12:39 PM
wasp9166's Avatar
no wrenchers here? bueller? anyone?
Old Sep 5, 2012 | 04:30 PM
CivicxTree754's Avatar
Photogenic
Loved
It doesnt matter either way. Even on reinstall you will have to rotate the cam/ rocker assembly to adjust the valve clearances.
Old Sep 5, 2012 | 04:31 PM
sstupid's Avatar
10 Year Member
Doesn't have to be at TDC.
Old Sep 5, 2012 | 06:04 PM
wasp9166's Avatar
yes, i planned on valve adjustment after all back together, then igntion timing as i'm replacing belt and tensioner as well
thing should run like a top when i'm done
Old Sep 6, 2012 | 05:14 AM
v4lu3s's Avatar
RTFM
i find it is easiest to set it at tdc before removing everything since i like to have it all set when i line it all back up at assembly time.
Old Sep 6, 2012 | 07:40 AM
sde780's Avatar
I do'nt put mine at TDC, but MAKE SURE the rocker assembly doesn't spring apart when you pull it off. Mine did and it took a loooong time to find all the pieces
Old Sep 6, 2012 | 07:58 AM
wasp9166's Avatar
i watched the video, how come his didn't spring apart?
wont loosening from outside in prevent this?
Old Sep 6, 2012 | 08:00 AM
wasp9166's Avatar
i was thinking this, i'd have to adjust #1 valves first anyhow, might as well get tdc b4 i start
Old Sep 6, 2012 | 11:30 AM
4drEF's Avatar
Keyboard Humorist
If you loosen the valve tappets then it can't spring apart.
If you don't loosen them, the valve spring tension will pop it apart.
Old Sep 6, 2012 | 11:59 AM
wasp9166's Avatar
i didn't see him do that, you mean back off the adjuster screws on all valves correct?
Old Sep 7, 2012 | 07:11 AM
sde780's Avatar
I didn't watch any video, but I'm just giving you fair warning so you don't end up searching your garage for random little pieces of your valvetrain. Keeping the bolts in the rocker assembly will also help keep it together
Old Sep 7, 2012 | 07:18 AM
wasp9166's Avatar
ahh yes, planned on not removing bolts
and i wont be in a garage, all the more reason to be careful
Old Sep 7, 2012 | 07:55 AM
4drEF's Avatar
Keyboard Humorist
Same part, different term. Honda technically calls them tappet adjusting screws.
Old Sep 7, 2012 | 08:23 AM
wasp9166's Avatar
one question i do have tho, why is i possible to adjust both intake and exhaust valves on the compression stroke? is it because they are all closed at this point?
Old Sep 7, 2012 | 09:29 AM
4drEF's Avatar
Keyboard Humorist
Probably more in depth than you need, but for others that don't know....
You want the valves shut and sealed on the head when the piston is coming up.
The springs are taking care of this job by pulling them up into place.
The tappets should have a gap so that the rocker is NOT pressing on the valve stem.
When there IS contact between the valve stem and tappet, then the valve is open - even just a little bit.
This gap is the valve lash.
So, during compression both intake and exhaust are closed just as you were thinking.
JPhilBradley's Avatar
BINGO!
Old Sep 7, 2012 | 11:40 AM
wasp9166's Avatar
yeah, i've done it before, just forgot, thought ex was done on a diff stroke than compression.....got it ,ty
ev94eg
Dec 10, 2012 05:43 PM
norco123
Aug 11, 2010 04:05 PM
Bevin
Aug 22, 2006 01:55 PM
dangrass
May 31, 2004 07:50 PM
