What do you think?
Old Oct 16, 2002 | 03:43 PM
Import RP's Avatar
Default What do you think?
Alright, here is the setup I hope to have soon on my 93 vtec.
-Apexi N1 exhaust
-AEM short ram intake
-greddy 4-2-1 header
-test pipe
-crower stage 2 cams, and valve springs/retainers
-hondata
Now, once I get it tuned right, what kind of times should i expect, and what might I dyno at? Thanks!
[Modified by Pyrochaos38, 4:43 PM 10/16/2002]
Old Oct 16, 2002 | 04:21 PM
Import RP's Avatar
Default Re: What do you think? (Pyrochaos38)
ttt
Old Oct 16, 2002 | 06:47 PM
Mike95lude's Avatar
-Apexi N1 exhaust
-test pipe
-hondata
Jeff, around 200 whp. Probably no more without headwork, raised compression or an aftermarket intake manifold.
Old Oct 16, 2002 | 07:29 PM
LilImportKid's Avatar
Default Re: What do you think? (Mike95lude)
Why not get a CAI?
Old Oct 16, 2002 | 07:58 PM
piotrush's Avatar
Default Re: What do you think? (LilImportKid)
Why not get a CAI?
and while you are upgading the valvetrain, throw in type s pistons.
BTW, that is the exact setup that I want, except for the header and test pipe - I plan on moding my collector to 2 1/4" and gatting a cat of equal diameter.
Good luck
Old Oct 16, 2002 | 09:21 PM
Honda318dx's Avatar
The SMSP header should by all means be ready by this winter... I see that as the only way to hit 200whp...
Old Oct 16, 2002 | 10:03 PM
Import RP's Avatar
Default Re: What do you think? (piotrush)
Yeah, I have considered type s pistons, but might just get a spoon head gasket or something. I dunno. How would the SMSP header, be in comparison to the greddy?
Old Oct 17, 2002 | 08:00 AM
piotrush's Avatar
Much much better but for much more $
Old Oct 17, 2002 | 09:02 AM
satan_srv's Avatar
Doubtful on the 200whp more like 190, although the Hondata has potential
Old Oct 17, 2002 | 01:12 PM
piotrush's Avatar
Default Re: What do you think? (satan_srv)
Corey's car has ~185whp with only AEM, smsp heared + straighthrough exhaust and CM flywheel. So I don't thinkanother 15whp is such a big leap with valvetrain and headwork.
Old Oct 17, 2002 | 07:43 PM
Mike95lude's Avatar
My last Prelude also made 183.5whp with only AEM, Greddy header, Apexi exhaust, and a slightly leaned V-AFC....didnt really do jack. Oh and I also had a CM clutch and shaved stock flywheel. I can guarantee if I had Crower cams, test pipe, and Hondata with wideband o2 tuning I would have flirted with 200 whp, no problem.
[Modified by Mike95lude, 8:44 PM 10/17/2002]
Old Oct 17, 2002 | 07:53 PM
Boostless97Lude
Guest
Posts: n/a
you kow what i think, i think i'm tired of these stupid *** ****** questions..... "how much power do you think this will add" bulshit!!!
Boostless97Lude
Guest
Posts: n/a
hehehehehehe....... j/k
Old Oct 18, 2002 | 12:33 AM
PrecisionH23a's Avatar
i say 190whp
athoughts
34
May 25, 2005 08:57 AM
AzG35
20
Jul 3, 2004 07:14 PM
99b18
45
May 11, 2004 02:50 PM
hYpE-R-29
Jan 27, 2004 10:45 AM
hYpE-R-29
17
Oct 7, 2003 07:48 PM
