civic 98 idle problem with A/C
hi
I have a civic 98 wich no maintein idle rpm when I turn on the A/C...just drop down the RPM untill the engine stop....take 30 sec since turn on the A/C to engine stop.
Any Ideas about this issue?
Clean IACV. https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
Then learn to use search.
Sorry, maybe you don't read well or I don't explain well... A/C means Air Conditioner not Air Control.
I did the IAC Maintenace and the idle is very fine at 750 RPM untill I turn on the Air Conditioner (A/C)...
Is not a IAC Problem, The Ecu isn't compence the A/C Load.
thanks for your answer any way
Hawaiian5.0
Apr 23, 2014 06:21 PM
Tom_Chooch
Dec 14, 2013 08:46 PM
skinney6
79
Aug 3, 2012 07:28 AM
