blink code 4 on a ef hatch
Old Sep 3, 2012 | 08:58 PM
Hondaguy1991's Avatar
Default blink code 4 on a ef hatch
I have a blink code 4. I have replaced the dizzy with a new. Car starts right up and and runs great 5 sec later it kicks the engine light runs ruff and then smooths out. I play with the dizzy timing and it clears up the idle a bit. The connectors are all good a the wires to the dizzy are not broken . I'm stumped. Is their another position sensor ? Is the car okay to drive a good distance like this? When I short out the timing connector the car doesn't bog out a 3 k it hits the rev limiter.
Old Sep 4, 2012 | 05:59 AM
dephtone's Avatar
Default Re: blink code 4 on a ef hatch
https://honda-tech.com/forums/showpo...35&postcount=5
Check this thread, I posted up the Factory Service Manual on how to troubleshoot code 4.
Get a multimeter and verify that you are getting the correct readings back to the ECU.
You will need to check the wires going into the ECU. I would start with the second photo, as that is pretty much where you are in your troubleshooting.
Syke909
Apr 3, 2013 01:31 PM
92_civic
Jul 13, 2010 02:07 PM
HatchMo
Jun 8, 2005 09:48 PM
ahc'monracing
Oct 8, 2002 04:43 AM
Cereal_Killer
Jan 25, 2002 01:52 PM
