Need help with my 91 CRX D15B2
My car has a rough idle and RPM's bounce between 1000 and 1500. Has a sputter on idle that almost makes it want to stall out. Has stalled out a few times when I just let it run. Any ideas as to what it could be? I've changed fuses, plugs, wires, fixed ground wires, battery cable, and installed a cold air intake but nothing has calmed down the sputtering.
i had the same problem on a 90 dx hatch years ago i cleaned my iacv and changed the map semsor and it solved my problem....just a thought n good luck hope u get her runnin good
Could you point out where exactly the map sensor is on the motor? I'm about to clean icav and would like to replace that too ... And may I ask where where did u buy ur map sensor ? Autozone is fine?
FERIOkid
Nov 11, 2006 04:07 PM
