How to force radiator fan to stay on? 98 EX
98 Civic EX 4-door automatic.
I want check the coolant temperature at the radiator as if the car is driving down the road, with lots of air flowing through the radiator. I figured the best way to do that is to force the radiator fan to stay on. How do I do that? The fan kicks on at about 210 degrees and shuts off at about 195, so there must be a switch somewhere. Can somebody tell me where? (P.S. It is NOT the coolant temp sensor near the thermostat -- when I short out that connector, all I get is a check-engine light, but no fan.)
So I figured maybe the computer turns the fan on based on the sensor, and if I shorted it out it would simulate hot coolant and turn on the fan. WRONG.
So there must be an actual switch somewhere else.
Wires are red and green. It is a sensor, not an on-off switch, and it is a couple inches below the thermostat housing, not on the housing. My shop manual shows a SWITCH right in the thermostat housing for some engines, but mine does not have that. The manual says the SENSOR has resistance of several thousand ohms (very cold) down to almost zero ohms (coolant at about 210). I have checked the sensor from 60 degrees up to 190 degrees, and the resistance is correct per the chart in the manual.
So there must be an actual switch somewhere else.See page 11-76 of the same manual, which has a little graph of resistance at various temps -- also calls the sensor a thermistor, and it can set codes P0116 through P0118. See also page 11-47 for a description. My car has the thermistor, but absolutely does NOT have the SWITCH screwed into the thermostat housing. Like I say, there has to BE a switch, but it must be somewhere else. On the radiator, maybe???
Yes, I have the D16Y8 engine, and yes, that is the ECT sensor. But getting back to my original question, there is no ECT SWITCH where we expect to find one. I wonder where it is?
You obviously don't want to jump that connector because you risk blowing the ECU. So the sensor you've been referring to is located below and slightly forward (front of car) of the distributor?
You either have a hybrid engine or somebody put the wrong thermostat housing on your engine.
Again, pictures will help. Start by locating the 2P connector with one green wire and one black wire, which are for the fan switch.
Consider that your engine may not have an ECT switch.
I finally found it. It is at the back of the engine toward the firewall, in the housing where the radiator hose returns from the bottom of the radiator. Thanks for your help!
ej888
19
Feb 22, 2023 12:37 PM
jessamychelle
22
Oct 19, 2011 05:29 AM
