ON - CAN 2000 honda civic coupe Dart block 2.2L Turbo
Dart Block, 84mm bore, 95mm knife edged crank, Eagle H beam rods, Arias 9:1 pistons, 2.2L
B16a Head, skunk 2 stage 2 pro 2 cams, skunk 2 intake manifold w/ throttle body, port matched, 1000 cc RC injectors, HKS SS BOV, 48mm pro gate wastegate, Equil length top mount manifold, GT35R ball bearing turbo, B16a transmission w/LSD, Avid drive shafts, Stage 4 clutch, 9LB flywheel, Aluminum rad, FAL fan, AEM wideband, Hondata S300 w/boost by gear, 460WHP @ 16psi. 130 000km on body, 3000km on motor
i dont get it, you got a straight serious built motor, an nice turbo setup, but crappy other parts, the front lip, headlights, the rims, the gauges, the fake carbon fiber bezel
Who cares, at least he spent good money on motor stuff, the other stuff is an easy fix if it bothers the "higher end" people!
gotufeenin
Sep 25, 2011 01:35 PM
highrevnef
May 17, 2005 11:15 AM
