subframe swap question
For those that swapped a 92-95 civic subframe on a 96-00 civic can you reuse the old bolts from the 6th gen civics to mount the subframe or do you have to use the 5th gen bolts. thanks in advance
also if I do have to use 5th gen bolts anyone know the part numbers for the bolts I would need.
i reused the bolts for the respective cars when i swapped mine. lessens the risk of bottoming out and stripping when using the air tools or having an overly long bolt that doesnt snug it into place
Doom325
May 14, 2010 03:06 PM
servion
Mar 5, 2005 02:05 PM
