OH 1991 Civic DX Hatchback B16A LSD Hasport Tahati Green...clean
GONE
Engine
1993 Del Sol B16A1 with 78k miles on it (Was Purchased from luckystarjapanese, have receipt)
Timing Belt, waterpump, and gaskets were changed at time of swap
98 Integra ITR Cams
Hondata intake manifold Gasket
NGK Blue Wires
Hasport B-Series Mounts
New Distributor and Starter
NGK Copper Plugs
Oddysey PC680 Lightweight Battery
ECU
OBD1 Chipped and converted P70 (JDM D15b) ECU
Locash OBD 0 to OBD-1 Jumper Harness
Engine Was street and dyno Tuned By Tom Sewell on ECTUNE (made 150 hp and 108 trq)
Trans
1993 JDM YS1 LSD Short Gear
2nd and 3rd Gear synchros have ~30k on them
Exedy 8.5 lb Flywheel
Exedy Clutch (Oem spec)
B&M Edge Shifter
Hasport Shift Linkage
S2000 Shift **** (note will not sell with car)
Exhaust
Chikara Header
2.25 inch Cat
2.25 OBX mid-section Pipe
Flowmaster 40 muffler
Suspension
Koni Yellows with Ground Control Coilovers
SPC rear toe adjusters, Ingalls rear Camber Arms
SPC front upper Camber Adjust
Energy Suspension Master Kit
Alot of the suspension and Bolts have less than 15k on them
Braking
15/16 EX master Cylinder
90-93 Integra Trailing Arms with Disc Brakes
Integra Proportioning Valve
New E-Brake Cables
Hawk HPS pads
Brembo Blank Rotors
Goodrich SS lines
Interior
1989 Integra DA Front and Rear Seats
1991 Prelude Steering Wheel
1999 Integra GSR Console Swap
Pioneer Headunit With USB and remote
Relocated Fusebox
New Front Pioneer Speakers
Rear Pioneer Speakers (rare SI pods
Peel in Seal applied to Front Doors and Rear of vehicle
Wheels
Mugen RNR replicas 15x6.5
195/55/15 Yokohama Tires (plenty of meat)
heres a few pics...
Engine
98 Integra ITR Cams
NGK Blue Wires
NGK Copper Plugs
ECU
Trans
B&M Edge Shifter
Exhaust
Chikara Header
2.25 inch Cat
Suspension
Braking
New E-Brake Cables
Hawk HPS pads
Brembo Blank Rotors
Goodrich SS lines
Interior
Relocated Fusebox
Wheels
heres a few pics...
I want this so so bad! I'll be home in November from this deployment. GLWS! PM me closer to November if you still have it, I'm willing to pay full amount
I live near Kent.. was curious if you were gonna actually sell it... I literally just bought a 89 hb... 4-speed grandma car.
Just saw this and started thinking.. i want a b16a in mine, but if your selling yours I could just use mine for a work car. PM me if your are selling. Thanks.
Price Drop I will take 4100 on white rotas.. or 3800 Bring your own wheels...no less
Looks good, bump for you.
Pedro likes it too -- http://pedroapproves.com/1991-civic-...-tahati-green/
