Help with condenser fan
Old Sep 1, 2012 | 09:03 PM
808zrk's Avatar
Default Help with condenser fan
car is a 08 tsx, but im sure it applies to more. Anyways, is the condenser fan suppose to engage when you turn the a/c on? Im pretty sure it is, but for some reason my gf's tsx fan doesnt turn on when i turn the a/c on, only the rad fan engages, any help appreciated
Old Sep 2, 2012 | 06:03 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Help with condenser fan
See if it gets voltage with the ac on. If it does the fan motor is bad. If it doesn't check the fuse, relay and switch.
Old Sep 2, 2012 | 12:49 PM
808zrk's Avatar
Thank you sir, I will check the voltage. I know the relay and fuse is located in the engine bay fuse box, but where would I find the switch? Thank you
*edit* checked the voltage of the power supply with a/c on, and I get power, power goes away with a/c off, so im concluding that the fan motor is toast.. Kind of disappointed a 4 year old cars fan motor failed when I have friends with cars from the early 90's that have oem a/c components..
Old Sep 2, 2012 | 03:12 PM
Technical Hero
Welcome to the new Honda
Old Sep 2, 2012 | 08:47 PM
808zrk's Avatar
97civicowner
34
Aug 27, 2018 06:09 PM
killaberna
Sep 14, 2015 10:06 AM
clowery89
Jun 23, 2010 06:17 AM
justa4dr
Feb 1, 2010 10:35 AM
93h22a1vtec
Mar 11, 2006 09:57 AM
