Aem serial logging
Old Sep 1, 2012 | 04:08 PM
siguy2k's Avatar
Default Aem serial logging
So I wired blue wire from aem wideband to pin 2 o n serial cable and then grounded 5 and it doesn't work. Ive got it set in Neptune to direct serial and gauge on that and it just reads 0? Ideas? Thanks alot.
Old Sep 2, 2012 | 10:47 AM
HRTuning's Avatar
Default Re: Aem serial logging
Direct Serial Logging From LC-1, LM-1, LM-2 (LM-2 USB Is Fully Supported), and PLX Wideband Products.
AEM is not listed, so you'll have to use an ECU analog input.
Old Sep 2, 2012 | 07:03 PM
siguy2k's Avatar
gotcha. So if I run it to d14 should I ground to a26 like I read?
Old Sep 4, 2012 | 05:48 AM
HRTuning's Avatar
Yes, ground it with the ECU.
Old Sep 4, 2012 | 11:39 AM
xenocron's Avatar
Make sure you are not putting the BLUE wire to the ECU...make sure you are sending the WHITE wire to D14
Old Apr 10, 2022 | 12:51 PM
tiemze's Avatar
Good info guys! So Do you cut the wire from the ecu harness at d14 and connect that directly to the white wire from the wideband? What do you do with a26? Ground the wideband to it by splicing into it?
https://technet.ff-squad.com/wiring.obd1.htm
Not sure if Neptune was updated since this post but there is an AEM option now but it still didn't work.
edit: found it. This should be sticky https://www.hamotorsports.com/pages/...g-instructions
mmcsiggi
Engine Management and Tuning
Jun 16, 2012 08:25 AM
Laojoeturbo
Jan 12, 2010 10:21 PM
[Ennis_D]
Jan 7, 2010 11:01 PM
[Ennis_D]
Jan 7, 2010 12:52 PM
Alpinestar03
Jan 1, 2009 08:54 AM
