98 Honda Civic P0172
!998 Honda Civic LX D16Y7 195k Automatic. Initially had a rough/surging idle problem, cleaned throttle body, injectors are good, new spark plugs, IAC valve good. Car idles fine but running conditions are crap. Loses power at seemingly random times. Finally ran diagnostic tool and came back with P0172 System Too Rich (Bank .1). Previously threw a P1456 But that has since gone away and not returned. Freeze Frame Data is as follows
Throttle Position: 9.8%
Engine RPM: 1261
Load Value: 19.6%
Map Sensor: 21 KPA
Coolant Temp: 197 Degrees F (Water Pump issue [resolved])
Intake Air Temp: 109 Degrees F
Short Term Fuel Trim (1): o.o%
Long Term Fuel Trim (1): 3.9%
Short Term Fuel Trim(3): -100.6%
Long Term Fuel Trim(3): -100.6%
Speed: 34 MPH
Fuel System: Open 1
Fuel System 2: N/A
I am absolutely stupified and don't want to spend more money replacing parts that don't need it. I almost threw away $170 on an IAC valve that I didn't need. Please!!!!! HELP!!!!!
Engine RPM: 1261
Load Value: 19.6%
Map Sensor: 21 KPA
Speed: 34 MPH
Fuel System: Open 1
Fuel System 2: N/A
Adeldis
Jul 17, 2012 03:59 AM
Darsholn
May 31, 2011 08:32 AM
kapoosh valve
Honda Civic (2001 - 2005)
Jul 4, 2010 12:00 PM
