n00b alarm questions
Old Sep 1, 2012 | 09:13 AM
BrotherAli's Avatar
Default n00b alarm questions
Does the valet button make your alarm useless if a thief finds it? Reason I ask is I think the avital 5303L has the button built into the antenna. It seems like everyone is worried about stealth installs and taking care of every vulnerability but I didnt see anything about the valet button?
Can I wire in a backup battery w/charging off the brain without having to buy 520T battery system? It would suck to have to buy 520T just to replace the battery with a better one. Anyway to just avoid the 520T system altogether and use a different battery or just buy the wires from the 520T without battery?
And if I want to install myself (dont have $ to just throwaway) am I screwed if I have a defective unit? What do some of you other diy guys do? Plug it in and hope for the best?
Thanks guys look forward to DIY my first alarm system (should be fun lol)
Old Sep 1, 2012 | 09:07 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: n00b alarm questions
valet button - the key/ignition has to be in the "ON" position (along with pressing the button) in order to silence the siren. The siren will still go off if you don't disarm the alarm.
Don't be a cheapass and just buy a DEI 520T. They're not like $500 or anything.
Old Sep 2, 2012 | 08:30 AM
BrotherAli's Avatar
So if a thief breaks in and has a worn key couldnt he use that while pressing the valet button to disarm?
Old Sep 2, 2012 | 09:02 AM
BrotherAli's Avatar
Another question I had is how do the window modules work? What I mean is how do they know if the windows are down and when to stop applying power to the window motors? I know if the window is up and I hit the up button the motor is actually trying to go up and drawing power.
Old Sep 2, 2012 | 12:55 PM
NVturbo's Avatar
O.G. triple O.G.
That's why the valet button is usually well hidden, not in plain view.
Are you referring to window rollup/roll down via remote? For that feature, you will need to wiring in relays and window control modules. No offense, but that may be too much for you to do by yourself. Let someone knowlegdeable install it.
Old Sep 2, 2012 | 01:35 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
You dont leave the valet button to the default setting. You change it.
Old Sep 2, 2012 | 03:50 PM
BrotherAli's Avatar
I see I thought the valet button was incorporated into the antenna on the avital 5303 but looks like im mistaken.
That makes sense thanks for the info.
Old Sep 2, 2012 | 04:39 PM
You can also modd the anttena and put a regular button
szczerbanator
Audio / Security / Video
Apr 24, 2010 03:02 PM
Jdmglenn
Jan 20, 2008 08:08 PM
robble36
Jan 8, 2007 04:03 AM
IntegraChick
Jun 1, 2005 08:01 AM
jond
Sep 7, 2001 04:21 AM
