Overkill?
Old Jan 20, 2008 | 10:39 AM
Jdmglenn's Avatar
Default Overkill?
I currently have a 791xv with the dei 515r backup siren with the key. I'm thinkin about adding a 520t back up battery also. Is this overkill? Am I good enough with the backup siren?
thanks
Old Jan 20, 2008 | 11:37 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Overkill? (Jdmglenn)
Since you have a 2way paging alarm the extra BUB will greatly benefit you. If your battery gets disconnected before the alarm is triggered you will be warned VIA your remote with the BUB installed. Also most alarms are setup with a normally closed kill so if you take power from the alarm, you can start the car. With the BUB installed this will not be the case.
Old Jan 20, 2008 | 05:46 PM
suspendedHatch's Avatar
No it's not overkill as a battery backup siren and a battery backup module are two different things with two different functions.
Old Jan 20, 2008 | 08:08 PM
Jdmglenn's Avatar
Default Re: Overkill? (suspendedHatch)
ok sweet. I just ordered the back up battery. (dei 520t). Bought some switches too, gonna make some kill switches
Chris1954
May 23, 2017 09:26 PM
Luchini
Audio / Security / Video
Jun 16, 2010 09:00 AM
ntoxicatedtigah
May 4, 2009 08:49 AM
hatching
Jun 28, 2007 10:33 PM
