TPS adjustment issues.
Old Sep 1, 2012 | 07:30 AM
crxguy406's Avatar
Default TPS adjustment issues.
So I keep trying to adjust my TPS to spec... but each time I get the low end set, the WOT goes off... and if I get the WOT set, the low end goes off.
Question. Does this mean bad TPS?
If I keep this TPS, does the motor suffer less to leave the low end or the WOT off spec slightly?
Old Sep 1, 2012 | 09:31 AM
Former User's Avatar
Default Re: TPS adjustment issues.
Post the voltage readings at closed and WOT.
Old Sep 1, 2012 | 11:16 AM
crxguy406's Avatar
most recent attempt gave me...
.50 closed = 3.87 WOT
4.45 WOT = 1.12 closed
Old Sep 1, 2012 | 11:51 AM
TeamRedline89Hatch's Avatar
Is it an Auto Zone replacement? Mine was off a bit but not by that much.
Old Sep 1, 2012 | 02:09 PM
Does 5V reach the TPS connector from the ECU?
Old Sep 1, 2012 | 03:43 PM
gringo7718's Avatar
The Official Honda TPS wiring and calibration thread
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
(yes the input voltage should be 5 volts.)
Old Sep 1, 2012 | 04:03 PM
https://honda-tech.com/forums/showthread.php?t=2830131
^Really nice DIY.
I have a couple of suggested minor edits:
***Key must be in the ignition to the ACC position to test power and signal***
This^ should instead say:
***Key must be in the ignition ON(II) position to test power and signal***
Also, for 92-00 Civics, removal of the hood ECU back up power fuse often requires several minutes rather than 20 seconds to reset the ECU. I'm not sure whether this is also true for 88-91 Civics. Can somebody else verify or refute this for 88-91 Civics?
Old Sep 2, 2012 | 10:59 AM
crxguy406's Avatar
Thanks for the links, ill check it out.
Old Sep 2, 2012 | 12:53 PM
gringo7718's Avatar
Originally Posted by RonJ@HT
^Really nice DIY.
Thanks RonJ.
You are right about the ACC vs ON II Position and I never even noticed.
As far as how long to wait for the ecu to reset....this will vary. In my EF, I pull fuse and 10-15 seconds is all I ever need. If you want to bleed off any residual power a little faster, you can disconnect the ground cable from the battery and step on the brake pedal. This should drain all of the residual charge and speed up the reset process.
Old Sep 2, 2012 | 06:14 PM
choocko's Avatar
you might want to slot the hole to give you more playing time and also take off the metal ring thing and just add regular washers because after you open those 2 slots the bolts will be too small.
Old Sep 2, 2012 | 07:53 PM
JuicedUpRice's Avatar
i just had a similar problem at the shop with a tt 300z.couldnt get the tps to show correct voltages.problem was the throttle cable had been rigged by the owners and was slightly open..we still got it close enough to run correctly though.
ARR777
Mar 6, 2018 01:17 PM
gringo7718
43
Nov 25, 2015 10:03 PM
rmcdaniels
Feb 21, 2009 08:22 PM
Darkteg
Aug 17, 2003 12:47 PM
NightHawkC5
Aug 16, 2003 06:04 AM
