GA FS/FT: RHD 1988 CRX Glass top SiR
Exempt from emissions as of Dec. 31. Antique!
Make: Honda
Model: EF7 CRX with SiR front end/motor. Real right hand drive with clean GA title/JDM vin.
Year: 1988
Color: OEM black
Miles: 140,000k
Engine: B16A from Hmotorsonline
Trans: Cable J1 with LSD
Price: $11,000
Trades: Other right hand drive cars I fancy or S2000.
Contact: Carina (678)334-7645 / Dylan (770)714-0134
Tuned by Scotty@MainStream
HP: 177
TQ: 113
Redline: 9,000 RPM
Engine and bay:
Brian Crower N/A stage 2 cams
Brian Crower flat faced valves
Brian Crower dual springs
Brian Crower steel retainers
Brian Crower keepers
Brian Crower adjustable cam gears
ARP headstuds
OEM headgasket
Gates racing timing belt
All new gaskets as follow:
OEM oil pick up gasket
OEM front main seal
OEM oil pump
OEM water pump
OEM oil pan seal
OEM cam gear seals
OEM tensioner spring
OEM thermostat
OEM PCV valve
OEM valve cover gasket
OEM vtec solenoid gaskets
OEM distributer seals
Dozen more I can't think of, $700 in new honda pumps and seals.
NGK sparkplug wires
NGK plugs
Hondata thermo intake gasket
ITR intake manifold
ITR throttle body
Nissan GTR R35 550cc injectors with HKS injector clips
Wire tucked engine harness
Wire tucked body harness
Hasport solid mounts
Mishimoto radiator
Mishimoto radiator cap
Custom radiator mounts
Finishing washers throughout the bay
Carbon whale ***** intake
Walbro fuel pump
Motul 300V 15w50 engine oil
Trans:
OEM Hondatrans fluid
2 new NAPA axles
Exedy clutch
Stock flywheel
Hasport shift linkage
No leaks
Interior:
Relocated light weight battery in trunk. Properly installed in battery box.
Full mint interior
JDM CRX back seat with seat belts
Front and rear full floor mats. Small spot on driver floor mat
Double din 7 inch headunit
Titanium shift ****
Mugen gen 1 wheel
Hub adapter
Power windows with auto up and down driver
JDM climate control
JDM clock
JDM EF8 cluster
Unknown JDM door panels
All lights work
JDM road flare
Hondata s300 on P28
Boomslang obd1 conversion harness
Sqwash airx
Stock JDM seats/ does not come with Bride
Exterior:
EF8 body conversion
Glass top with zero damage
New front windsheild
New front window molding
JDM fog lights
Carbon front lip
Carbon JDM style hood with now washer holes
OEM JDM rear wing
Lots of OEM JDM decals and badges
JDM tail lights
JDM side markers
Window visors
Exhaust:
Toda style header
Full 2.5 inch exhaust with Skunk2 muffler
Includes silencer
Suspension:
Tein Super Street coilovers
Black beaks bar
Skunk2 control arms
New Moog outer tie rod endlinks
Power steering rack with no power steering.
Front and rear sway bars
Brakes:
Motul RBF600 brake fluid
EBC Yellow front brake pads
OEM Honda rear brake pads
Slotted front and rear rotors
Wheels and tires:
Wed sports 16x7 +35
Nitto neogens 205/45/16
Neo chrome lug nuts
Make: Honda
Year: 1988
Color: OEM black
Miles: 140,000k
Price: $11,000
HP: 177
TQ: 113
Redline: 9,000 RPM
Engine and bay:
ARP headstuds
OEM headgasket
OEM front main seal
OEM oil pump
OEM water pump
OEM oil pan seal
OEM cam gear seals
OEM thermostat
OEM PCV valve
NGK sparkplug wires
NGK plugs
ITR intake manifold
ITR throttle body
Mishimoto radiator
Walbro fuel pump
Trans:
2 new NAPA axles
Exedy clutch
Stock flywheel
No leaks
Interior:
Full mint interior
Titanium shift ****
Mugen gen 1 wheel
Hub adapter
JDM climate control
JDM clock
JDM EF8 cluster
All lights work
JDM road flare
Hondata s300 on P28
Sqwash airx
Exterior:
EF8 body conversion
JDM fog lights
Carbon front lip
OEM JDM rear wing
JDM tail lights
JDM side markers
Window visors
Exhaust:
Toda style header
Includes silencer
Suspension:
Black beaks bar
Skunk2 control arms
Brakes:
Wheels and tires:
Wed sports 16x7 +35
Neo chrome lug nuts
JDMH22HATCH
Jan 15, 2009 02:19 PM
