ZC swap code 9 (cyl sens) so close, yet.....
Im getting a code 9 (cyl sen) and I have taken the pins out, switched wires,switched wires again just to make sure and no change. I have tested ground in sensor and pins and even looked at the signal on a snap-on vantage, everything looks normal. This of course answers my last post about my engine being flat under load. But I have noticed that under load my temp. gauge is irratic and when Im of the gas it returns to a accurate reading. I feel this might have something to do with it but ?
I have the cyl. sen. running to c1 c2 the first pins on the C connector( over,under) on the ecu Im sure thats the right location. So if you guys can help out please do.
If you come to the point where you want to purchase another cylinder position sensor I have one for sale. It was one of the things when I was trying to find out what was wrong with my car.
wire that was originally at c1 needs to go to B connector 5th pin from left - bottom row - - wire that was originally at c2 needs to go to B conn. 6th pin from left - bottom row - - new wire from c1 to blu/grn on cyl. pos. sensor - - new wire from c2 to blu/yellow on cyl. pos. sensor
