help with Bswap in ek hatch
i know i know, google it. and i have. tons of info all over the net but not what im looking for.
what i want to know is simple,
what EXACTLY is needed to do a bswap into an ek hatch? details i want are:
what parts
what vehicle can i find the parts on if i were to find them at salvage yard
even if parts need to be modified to work, what parts are they and what can can i get them off of.
DONT TELL ME TO BUY HASPORT MOUNTS. **** THAT, I WANT ALL HONDA PARTS. there HAS to be a way... after all, they DO come with these motors in them in japan.
I will say, it LOOKS like the mounts from CRV will work but i have not tested and dont have a way to test them. all i am saying is they appear to be very similar to what ek may require for bswap.
motor im going to be using is a built b20v in a midori green hatch.
what parts
Here you go...what parts and what vehicles they come out of, including OEM mounts: https://honda-tech.com/forums/hybrid-engine-swaps-18/my-b20-into-ek-parts-list-504321/
You don't even need to use Google for this - just a little common sense.
A) B20, B16, B18, doesn't matter, they all use the same mounts.
B) The 99-00 Civic SI has a B16A2. The 96-00 Civics all use the same mounts, except the rear T bracket.
A + B = use your stock mounts, and replace your rear T bracket with one from an EM1, zero modification required.
