core support replacement
im replacing my core support on my hatch, and i have already started drilling out the little welds on it, and the obvious ones ive already done, but i dont know if i need to drill all the ones i see (god i hope not), or if there are certain ones i need to do in rder to pry this thing off. so if anyone has a daigram or a link to it, please let me know. thanks.
there's alot of weld spots.... They make a special drill bit thing for drilling out spot welds. Not sure what it's called or looks like, I've just head of it. Think Sears has it?
I just recently did mine, you have to drill out every wield.Make pilot holes with a small drill bit then go over it with a bigger bit to go through the entire wield. You will also need a chisel to make life easier when prying it off.
I wasn't able to find the but without ordering it, but I have been drilling pilot holes and going back with a bigger bit. I was able to that thing off last night with a sharp cold chisel pry bar. Thanks for the help
Welding / Fabrication
12
Jan 29, 2006 07:23 PM
