Car has hard time starting up first time
Old Aug 29, 2012 | 09:50 PM
OhShietTommy's Avatar
Default Car has hard time starting up first time
Well i just recently installed a deck and now the car has trouble starting after leaving it overnight or for long periods of time. The first time starting it wouldnt work but then after that it starts up fine. its might be the wiring but not sure
Old Sep 1, 2012 | 09:12 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Car has hard time starting up first time
Check your wiring. If you are having issues, more than likely you EITHER used crappy butt connectors or just taped the wires together. GHETTO methods lead to other problems.
Old Sep 2, 2012 | 09:53 PM
Bradshaw's Avatar
as long as the wires are connected to the correct ones, shouldn't be having those problems.
does your head unit stay on after you turned the car off? what was the quality of the install? did you use an interconnect harness? or just hack the oem and twist up wire colors your best friend told you were right?
Dead CIVIC
Audio / Security / Video
Jan 23, 2015 06:24 PM
RedHurricane
Jan 31, 2011 09:51 PM
Wolfwood
Aug 30, 2005 04:20 AM
GrayT
Jul 7, 2005 11:51 AM
Styles
21
Oct 15, 2004 12:21 PM
