['94 Civic EX] Slow turn over then starts (solved)
So my '94 Civic EX has begun to sound odd when starting. It turns over once, slowly, then fires up. So it sounds like: "Chug - Vroom!" Could it be a battery problem or something more serious?
Thanks in advance!
Thanks in advance!
last time you did full tune up?
plugs/wires/etc?
You can get a free battery/alternator test at autoparts stores....or they sell testers. I got an alt tester for $2 at harbor freight....
plugs/wires/etc?
Battery or battery cable/connection tightness/corrosion. Test battery first then cables/connections. Apply dielectric grease to new/clean connectons.
Thanks for all the replies, it's good to hear you all think to start with the battery. I haven't changed my battery in at least 6 years. I will look into it, I'll post back with the results as soon as I get it looked at. Oh, and I know I'm due for a major tune-up, but I cannot afford it right now, but such is life.
^6 years....
then its definitely your battery....
once winter hits, it'll die on you. better start saving now. expect to spend 100 on a good battery. if you find a 40-50 dollar battery, expect 2 years out of it, tops
tommy boy2
19
Nov 21, 2014 05:26 AM
si_motor_spt
17
Mar 27, 2011 12:10 PM
