can't take off skunk2 knob> locking nut stripped
Old Aug 29, 2012 | 12:05 PM
97civic123's Avatar
Default can't take off skunk2 ****> locking nut stripped
i bought a civic w/ skunk2 **** & skunk2 short shifter. Well the previous owner worn out the locking nut on the shift ****, where i can't get any grip on it. I tried pb spray, wd40, vice grip on the nut,metrinch wrench, and also even try to hammer a smaller combo wrench around the nut (out of frustration)...any suggestions?
Old Aug 29, 2012 | 12:23 PM
surfingsk8r's Avatar
Default Re: can't take off skunk2 ****> locking nut stripped
cut it and replace with a stock shifter is my vote.
Old Aug 29, 2012 | 12:55 PM
HondaPartsHero's Avatar
Technical Hero
Dremel it off
Old Aug 29, 2012 | 04:50 PM
97civic123's Avatar
Originally Posted by HondaPartsHero
Dremel it off
i want to avoid cutting the short shifter.
Old Aug 30, 2012 | 06:04 AM
could try a nut cracker to split the nut but a lot of times it damages the threads its on. If you have the correct size die though you could fix that.
Old Aug 30, 2012 | 07:54 AM
Technical Hero
You can cut off the nut without damaging the shifter
Old Aug 30, 2012 | 05:11 PM
MonkeyMagic's Avatar
then do it with some degree of care?
no doubt
fwiw, short shifters suck anyway. i'd cut the f'er in half and buy a new one off ebay for $12 shipped.
Old Aug 30, 2012 | 05:28 PM
90civicstdgold's Avatar
Avoid the Skunk2 unit and go back to stock.
The OEM GS-R shifter has a nice throw and can be made to fit into a civic with little modification.
ej6fade
12
Apr 12, 2014 06:36 AM
diewnaylomoah
May 25, 2007 08:34 PM
vc
Apr 21, 2006 09:55 AM
PinoyCivic
10
Feb 21, 2006 01:42 PM
DownBoyDown
Jul 24, 2003 03:26 PM
