Honda CR-V & Element 2WD & 4WD Element & CR-V
2006 Honda CRV coughing and sputtering
Old Aug 29, 2012 | 11:28 AM
ReverendFred's Avatar
Default 2006 Honda CRV coughing and sputtering
I have a 2006 Honda CRV. It has about 145k on it. It has begun coughing and sputtering when under any load at all, accelerating, going up hills, etc. but it runs fine at steady load. I am getting an occasional sulfur smell. Last night the Check Engine light came on and stayed on. This morning it was off but them came back on. Any ideas?
Thanks,
Fred
Old Aug 29, 2012 | 07:50 PM
el crapitan's Avatar
Default Re: 2006 Honda CRV coughing and sputtering
check the codes?
sulfur smell is usually due to high HC content
check the codes
Old Aug 30, 2012 | 05:08 PM
I'm getting a P0303 code.
Old Aug 30, 2012 | 07:53 PM
well then. you have the problem cylinder id'd. time to dig further.
pull the spark plug and have a look at it. HEI test the coil. check for injector pulse. check compression. those are what i'd do
Robin1955
Engine Management and Tuning
Nov 9, 2013 06:59 AM
hckyNhonda29
Jan 18, 2007 07:27 PM
teamitr
Aug 24, 2006 04:28 PM
willyboyK20
Jul 2, 2003 08:10 PM
