no oil pressure? oil pump is brand new
Old Aug 28, 2012 | 11:58 PM
superspadez's Avatar
Default no oil pressure? oil pump is brand new
i just replaced the oil pump in my h23a and my oil pressure guage is not reading any oil pressure? pick up was clean no cloggs. ive used the search bar for 2 hrs now and it says the same thing. help please!
well i;m pretty sure i'm getting oil in the head. took off the oil cap while engine is on and see the little drops of oil jump out and engine isnt making any weird noises besides idling shitty. no ticking or knocking. oil has no metal shavings.
the gauge stopped working after i did the swap. there are no crimps in the hose.
the engine
Old Aug 29, 2012 | 01:42 AM
shipo's Avatar
Default Re: no oil pressure? oil pump is brand new
Did you replace the oil pump because the gauge was showing no pressure?
If "Yes", did you validate the sending unit is accurate prior to the oil pump change?
The thing is, I find it HIGHLY unlikely that two consecutive pumps would be unable to generate any pressure; that leads me to conclude one of the following things is wrong with your engine:
  • The sending unit is bad
  • The main and rod bearings are completely shot and all of the pumped oil is just being dumped back into the pan
Old Aug 29, 2012 | 02:17 AM
holmesnmanny's Avatar
If you use too much teflon tape it is possible for it not to ground properly to the block.
Old Aug 29, 2012 | 11:54 PM
i replaced the oil pump for a swap. but my oil pump guage was still working fine before the swap. the motor runs and stays on and sounds normal
Old Aug 29, 2012 | 11:56 PM
i am using an mechanicl oil pressure guage. so i dont think ill need to worry about that. the
Old Aug 29, 2012 | 11:59 PM
Did you run it with an OEM switch and see if the light comes on ?
Old Aug 30, 2012 | 10:18 AM
no...i took off the switch because i had an oil pressure guage
Old Aug 30, 2012 | 04:32 PM
Hidenplanvew's Avatar
are you sure the gauge works?
Old Aug 30, 2012 | 10:30 PM
Old Aug 31, 2012 | 01:38 PM
yes. the gauge was working before i swapped out the motor
oscar112709
Apr 18, 2019 12:52 AM
xlasianizelx
Aug 10, 2010 02:28 PM
EG6 Love
Feb 6, 2010 09:53 AM
90Rexx
17
May 5, 2008 06:06 AM
jtracing919
Mar 25, 2006 08:23 PM
