Allen head plugs on timing side of motor, leak?
Old Aug 28, 2012 | 05:40 PM
sirtef9's Avatar
Default Allen head plugs on timing side of motor, leak?
DO any of them leak oil if they are gonna leak? Just sealing that side up and don't want to miss anything.
Thanks
Old Aug 29, 2012 | 02:40 PM
DraginX's Avatar
Default Re: Allen head plugs on timing side of motor, leak?
If you forget to put in the aluminium washers with them they will leak.
Old Aug 29, 2012 | 06:53 PM
sirtef9's Avatar
havent pulled any yet, just checking if I should to re seal before all goes back together.
Old Aug 30, 2012 | 06:06 AM
surfingsk8r's Avatar
Yes they go to the oil galley in the motor if your referring to the ones that are on the TC side and the flywheel side, the ones on the back of the block are crankcase vent. Make sure you have the aluminum washers on there and get them tight and you should be fine.
byrne_06
Jul 4, 2013 06:54 PM
Jaemoney21
Oct 10, 2012 04:44 AM
PMK
Jun 27, 2011 07:50 AM
Corksil
May 9, 2011 04:42 PM
powerdbygarrett
Jan 4, 2008 07:35 AM
