Need help wiring up vtec solenoid and vtec oil pressure switch.
Old Aug 28, 2012 | 03:38 PM
95fourdoor's Avatar
Default Need help wiring up vtec solenoid and vtec oil pressure switch.
Okay so about three months ago i bought a 1995 Civic with a full gsr swap and i got it for dirt cheap so i had to jump on it. but im having problem my vtec. i dont think its hooked up correctly because on the p72 pin out it says that the vtec oil pressure switch goes into D6 but there is a wire in d6 thats goes straight to the vtec soleniod. so i believe it is wired wrong but i really want a second opinion before i change any wire i really need help so i can figure this out.. so if anyone could maybe tell me where on the p72 ecu the vtec soleniod wire and vtec oil pressure switch goes that would be much apreciated!
Old Aug 28, 2012 | 05:26 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Need help wiring up vtec solenoid and vtec oil pressure switch.
Old Aug 29, 2012 | 01:01 PM
95fourdoor's Avatar
Thanks Man! that is for the p72 ecu right? just double checking before i do anything.. thanks for the quick reply as well
See Are X
Sep 4, 2024 03:31 PM
tofastgsr
Engine Management and Tuning
Oct 26, 2012 06:11 AM
blueeg
Apr 25, 2006 11:16 AM
sharkcohen
Mar 11, 2005 07:55 AM
