seating cam and crank seals?
Old Aug 28, 2012 | 02:39 PM
wasp9166's Avatar
Default seating cam and crank seals?
how do you guys know for sure the seal is installed correctly? i've been told that it can look fine from outside but it can be rolled on the inside edge..........would a little oil prevent this? or is there a special tool
Old Aug 28, 2012 | 04:57 PM
crvtectim's Avatar
Default Re: seating cam and crank seals?
Yes, most definitely lube up the lip of the seals to prevent dry start tearing of the seal. One trick to preventing the spring from popping out if you accidentally roll the lip is to pack grease in the back side of the seal. Take special care that you're tapping the seal down flush. They can be tricky so have some patience.
Old Aug 29, 2012 | 02:03 PM
wasp9166's Avatar
had no idea the seal had a spring in it
TravisB16a
Apr 18, 2011 05:07 AM
dleccord
Jan 27, 2010 05:55 AM
HudsoN
Jun 2, 2009 04:09 PM
Si-Samuri
Oct 27, 2008 07:45 AM
ironcheftony
May 14, 2007 08:36 PM
