VTEC oil pressure sensor?
Its the OEM oil pressure sensor, looks like that motor has a massive aftermarket pressure sensor to the left of the oil filter(gold piece). That's where the oem sensor went. you're running an oil filter sandwich plate that is used to add oil pressure ports to send oil to vtec heads if ls/b20 block, or sending oil to turbo.
I use a Oil feed adapter from B&R fiting for the 'massive" (lol) aftermaket sensor for a gauge and the Turbo oil feed
Can I do different?
you need to mount the gold pressure sensor as a remote unit in the firewall to prevent breakage of the unit by weight or damage the trhead. And the green sensor is the stock oil warning light.
