Radiator fan not turning on
Old Aug 27, 2012 | 08:52 PM
EK9JSPEC's Avatar
Default Radiator fan not turning on
What control's the radiator fan to come on? Seems like my radiator fan is not turning on making my temp gauge rise then fall back down,just did my coolant flush,thermostat,coolant temp switch also
Old Aug 27, 2012 | 09:06 PM
ANNiHiLATORS's Avatar
Default Re: Radiator fan not turning on
Fan switch sensor.. On thermostat housing
Old Aug 27, 2012 | 09:11 PM
Ryan Lwin's Avatar
First of all, check for the fuse in the under-hood fusebox.
If that's ok, unplug the temp switch right above where the thermostat and bottom radiator hose meet. Then with the key at ON position (without starting the engine) short the two pins from that relay using anything conductive. Screw driver or wire. See if the fan turns on.
If that doesn't work, check for the voltage across the lead where the fan is connected while the relay is still being shorted.
redbull99
Aug 27, 2015 10:19 AM
nfiniti9
Jun 9, 2012 02:14 PM
JH4DB858
Jan 10, 2012 07:32 PM
jkalex05
Aug 22, 2009 07:02 AM
esean93
11
Jul 29, 2008 05:33 PM
