TN 1996 prelude si vtec nashville FS FT
Old Aug 27, 2012 | 12:22 PM
mt23vtecbb2's Avatar
Icon5 1996 prelude si vtec nashville FS FT
1996 honda prelude si vtec, owned for 12 years 2nd owner, everything about the car is topshelf, all parts and mods are top of the line, no ebay junk parts. was the cover car for hondatuning mag march 07. i dont have much time for the car anymore, still drive it when i can, runs perfect and is solid and fast, i have a lot of stock and other parts to go with it. the body has around 130k on it. still has the flawless og 96 honda paint . was looking to sale but i may trade for 08 and up cbr1000 rr, or??? just let me know dont hurt to ask. asking 12000 obo. i have looked at shipping shouldnt be a prob. i can send a link with tons more pics. see the list below for all the mods. thank you. call or text or email. 615-519-1583 if no anwser please leave message. thanks again.
1996 honda prelude SI (BB2)
96 only heather mist met. origanal paint job
inside-
all black swapped interior
black suade headliner
memory fab carbon kevlar s58 seats
TDM low down sliders/ custom rails
sparco stering wheel & hub
razzo **** & pedles
autometer shift light (hide in ac vent)
hidden fuse box (pass air bag tray)
stock EL gauges
JDM climite Control
outside-
jdm black housing hedlights (new from honda)
jdm front bumper lights (96 only all clear) - 100
jdm front bumper & light weight bumper suport
jdm rear bumper
accord rear lip (cut and sectioned)
Vis oem carbon hood
road race eng. carbon vent
sibon carbon front lip
front splitter
painted side skirts
vision type MC carbon mirriors
BB6 glass sun roof
jdm tail lights
McCulloch bi Zenon H3 6000k HIDs (high and low beam)
rayburg h1 yellow, high beam swap
audio-
sony cd mp3 cdx660
vtec prelude amp
6x9 infinty sub in stock vtec location
infinty kappa 6.5 door
infinty kappa 6.5 rear deck
direct electronics 2 way keyless alarm with pager
ecu-
hondata p28 obd2 converted ecu (no jumper)
hondata s200
chassis-
k sport pro full coilovers
tanabe rear lower tie bar - for all 4 tanabe bars
tanabe front lower tie bar
tanabe rear upper tower brace
tanabe front upper tower brace
em racing c piller brace
chassis tech front Adj. upper control arms
ESP front cross brace & traction arms with the tourqe mount
brakes-
BB6 five lug swap
arp extended studs
titanum lugs
abs delete
earls SS brake lines
vtec front calipers
front BB6 drilled and slotted brembo rotors
rear BB6 drilled and slotted brembo rotors
hawk pads front and rear
synthic dot 4 fluid
motor-
h23a1 block, 88mm steel sleved
h23a1 crank, polished & knife edged
arp main studs
crower pro billit rods for h23a1
88mm je pistions 12:1 for h22a
je wrist pins & locks
wisco xe rings
h22a oem oil pump
h22a oem oil squarters
h22a oem water pump
h22a oem timming belt
h22a crank timming gear
h22a1 vtec head
full SFP port and polish
SFP 3 angle valve job and guides
rev titanim valves (stock size)
arp head studs
arp headder studs
skunk2 valve springs
skunk2 titunim retainers
skunk2 stage 2 cams
cometic head gasket
aem timming gears
h23a1 manual timming belt tentioner
place racing motor mounts
hondata heat shield
skunk2 pro intake manifold (port mached)
STR 70mm t body
aem fuel rail
areomotive fuel presure regulator
acell 370cc fuel injectors
EGR delete
sparco oil cooler all AN -8 lines
-6 AN fuel lines
elderbrock -6 fuel filter
3" BB6 aem cold air intake
greddy catch can -8 AN lines
rs*r jdm 4/2/1 SS headder 2.5 outlet
rs*r exmag full cat back
car sound high flow cat
mugen low temp fan switch
mugen low temp thurmostat
mugen ver 2 oil cap
mugen rad cap
mugen covers
fal single pusher fan
koyo alu rad
samco sport rad hoses
forbidden motorsports cooling plate
SCI ignition box
MSD blaster ss coil
ngk-r wires
ngk-r iridum plugs
polished red typeS valve cover
custom tucked harness
trans-
MS24 BB6 trans
act presure plate
act clutch disk
clutchmasters alu fly wheel
custom hidden clutch line
wheels-
custom made
CCW classic race ver. 5x114.3
16x8.5 +29 offset
225-45-16 yokohama es100
titanum lugs
Old Aug 27, 2012 | 01:22 PM
bsimongreat55's Avatar
Default Re: 1996 prelude si vtec nashville FS FT
This looks great!!!
Old Aug 27, 2012 | 03:37 PM
parksed24's Avatar
Sooooo good! GLWS
Old Aug 27, 2012 | 05:02 PM
thanks both of ya. hope that things are better in the world and people can afford toys again.
Old Aug 30, 2012 | 05:35 PM
since everyones taste is not the same, can be sold with out wheels, seats etc... can be worked out.
Old Sep 2, 2012 | 11:02 AM
not sure what i would trade for. just shoot them to me. well see thanks.
Old Sep 12, 2012 | 05:20 PM
had a few people ask so i thought id post, it was up for sale last year, had a guy who wanted to get it gave me some money to hold it, and pull it down for sale, and give him 6 months to come up with the rest. he got most but just could not get it togeather. so i did some more mods that i wanted to do this spring ant thought of keeping it, but i just hate to let it sit, so thats the deal. thanks.
Old Nov 16, 2012 | 12:29 PM
Dabrybry's Avatar
You sir...are doing it right. GLWS
Old Nov 16, 2012 | 02:44 PM
LSVTEC426's Avatar
looks gooooood
Heiko_Killinger
Jul 10, 2017 08:24 AM
Busabos77
Jun 6, 2011 08:11 PM
grippgoat
Jun 11, 2004 01:19 PM
Misfit
Aug 1, 2001 09:30 PM
