Turn signal problem...
Old Oct 16, 2002 | 11:19 AM
MisterB's Avatar
Default Turn signal problem...
my turn signal in the corner light will not blink, i changed the bulbs and also checked the fuses and there all good. the bumper light blinks and the corner parking light works but the signal light does not. Any body?
Old Oct 16, 2002 | 12:01 PM
Chris's Avatar
Default Re: Turn signal problem... (cl4show)
Is it the proper bulb?
It needs to have 2 filaments in it.
HTH
Old Oct 16, 2002 | 12:14 PM
EL Vap133's Avatar
Are all the wires intact, are the conections connected properly?
Old Oct 16, 2002 | 12:38 PM
MisterB's Avatar
Default Re: Turn signal problem... (Vap133)
i used a volt meter and it is not getting any power i tested were the bulb goes in also at the conecter and even the wire and no power
Old Oct 16, 2002 | 09:17 PM
MisterB's Avatar
anyone have any other ideas
Old Oct 16, 2002 | 09:24 PM
thaiphob's Avatar
Nikon!!!
maybe a loose conection somewhere.
Old Oct 16, 2002 | 10:00 PM
MaxED9's Avatar
Default Re: Turn signal problem... (thaiphob)
keep using that volt meter all the way back until you find electricity... theres your problem
thunderboy
Nov 7, 2007 12:01 PM
phoshizzle88
Sep 16, 2007 05:59 PM
niteboyzzz
Oct 4, 2002 11:24 PM
vertius
May 11, 2002 12:15 PM
