Need some help with wire colors in harness
Old Aug 27, 2012 | 07:05 AM
Chops13's Avatar
Default Need some help with wire colors in harness
Could somebody tell me what color wires are on the plug to the aic plug and air temp plug is? It's a b18b swap in an EG. Getting a cel 14 code.
Old Aug 27, 2012 | 10:35 PM
d15bvtechatch's Avatar
Default Re: Need some help with wire colors in harness
It depends on what year ECU/ENGINE HARNESS you are using.
Intake air temp is Red with Yellow stripe.
http://www.phearable.net/tech/wiring...schematics.gif
the blue plug
Old Aug 28, 2012 | 10:22 AM
Chops13's Avatar
From what I've read the green/white wire goes to the aic, but that's on the same plug as the air temp wire. It seems to idle fine with the aic unplugged. It doesn't really search for idle. I'll just have to check my ecu pin outs for the right one maybe. Its a harness off an auto ls.
Old Aug 28, 2012 | 12:42 PM
what year auto LS
Old Aug 28, 2012 | 12:52 PM
94EG8's Avatar
Seagull Management
blue/yellow and yellow/black (or something close to that) is IACV. IAT is red/yellow and green/white.
Old Aug 28, 2012 | 03:24 PM
Chops13's Avatar
I think that's it. Thanks. Only plug left would be for the evap. I'll check it after work tonight.
bpr00civicsi
Jun 18, 2018 06:23 PM
sive
Jul 16, 2013 08:29 AM
chrisfromsrq
Jan 24, 2010 08:37 AM
nytosc
Feb 25, 2009 06:49 PM
VTcivicHB
Nov 11, 2005 05:08 PM
