Can anyone advise why I can't read my guages at night even though my dash lights work
Old Aug 26, 2012 | 12:14 AM
PapillonOne's Avatar
Icon2 Can anyone advise why I can't read my guages at night even though my dash lights work
Hello all.
New here. I drive a 1994 Honda Accord Wagon EX. I really love her and try to keep her up and running well. I have already become so enlightened from reading the sticky notes you all have posted. I can see there are a few things I can fix as my Honda does have a few "leaks" I'd like to address. (Saw the ABS lead posts and now just have to search for a power steering fluid fix- lol)
My main question at this time is that recently I noticed while driving at night, that I no longer can read my speed or my gas level and other gauges. Not sure when this happened and since the only other light that is out is one of the preset buttons on the radio, I am not sure what lights are out that would cause this and need replacing. I can see all the numbers in the gauges but just can't see the little arrows and where they are pointing.
Not being able to tell my speed is a bit of a nuisance so I am hoping some one can share an easy fix (hoping big time.
Thank you for your time.
PapillonOne
Central Florida
Last edited by PapillonOne; Aug 26, 2012 at 12:15 AM. Reason: slight change to car description
Old Aug 26, 2012 | 05:10 AM
TalonIV's Avatar
Default Re: Can anyone advise why I can't read my guages at night even though my dash lights
Oh so it is just the needles on the guages you can't see? I wouls assume thee arebulbs behind them that illuminate them. May have gone out or possibly a loose connection behind the guage cluster?
Old Aug 26, 2012 | 05:24 AM
jdmcertified909's Avatar
TAKE A PICTURE AND POST IT SO WE CAN SEE WHAT YOU MEAN
Old Aug 26, 2012 | 05:29 AM
n9_accord's Avatar
I had the same Issue on my 97 Wagon and now my daily driver 96 Sedan.. I'm thinking there are bulbs back behind the needles for the dials that have limited life expectancies... I also have a 97 Sedan I picked up with a non-functional speedometer all together... If it comes down to pulling the gauge cluster out and swapping it, I will crack it open and see about those bulbs.. maybe get some pictures up!
Old Aug 27, 2012 | 01:10 AM
holmesnmanny's Avatar
lol there should be a **** that turns the light up. Look on the dash.
Old Aug 27, 2012 | 07:05 AM
That **** does change the brightness of the dash lights but has no effect on the lighting of the little needles inside of the gauges. It was the first thing I tried to adjust hoping that was what the problem was. Thanks for your suggestion.
Old Aug 27, 2012 | 07:10 AM
Only problem with that is, it is only at night in the dark that the problem occurs and I don't know how to take a picture that would not require a flash to get the dash area to show up in the picture and the flash would obliterate what I am trying to describe.
Everything inside the bezel(?) area lights up except the little needles of all of the gauges that tell me how fast I am driving or how much gas is in the tank, etc.
Any other suggestions would be appreciated. Thank you.
Old Aug 27, 2012 | 07:12 AM
That would be great! If it is an easy fix, I'd sure like to know it! Thanks.
Old Aug 27, 2012 | 07:18 AM
TheMuffinMan's Avatar
He knows where you live!
There are two overhead bulbs on the cluster that if they go out make it difficult to read the gauges.
You will need to remove the cluster in order to replace the bulbs.
*edit*
The needles do not light up at all, they are illuminated by those two bulbs I just mentioned. if you look upwards in the cluster you should see two translucent parts where the light shines through.
This image illustrates it nicely thanks to the LED swap, the two top most lights you see are what I'm referencing.
*edit2*
There are two cluster removal threads in the Accord FAQ that show you how to remove the cluster to a point that you can replace the bulbs.
Old Sep 3, 2012 | 06:35 AM
Post Re: Can anyone advise why I can't read my guages at night even though my dash lights
Thank yous to TheMuffinMan for the pix and reply. I read those 2 threads regarding cluster removal you referred to when I first joined the site. They're awesome, however I fear that it might be the kind of "repair" that is beyond me at this point in my life..... 59 year old "tomboy" that I am.
Odd that both bulbs would burn out at the same time though I guess if one goes it changes the voltage or amps on the other and takes that one out too maybe.
If I were to find someone to do it, is it hard or very expensive to swap out those lights for LED lights? May I ask if anyone can tell me what sort of lights were in there originally, incandescent bulbs? or was there some other technology back in 1994?
Thanks again. I love these forums and all the help I get from my Honda brethren.
PapillonOne
Old Sep 3, 2012 | 09:20 AM
Lost Again's Avatar
IIRC, these are #194 bulbs...been a while so my memory is suspect .
Old Sep 3, 2012 | 10:10 AM
djkurious's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/speedometer-temp-fuel-rpm-needle-not-illuminated-3068776/
http://www.autozone.com/autozone/par..._415152_18440_
Old Sep 4, 2012 | 02:51 PM
Lost Again's Avatar
Warned you my memory was bad.......
Old Sep 5, 2012 | 11:55 AM
PapillonOne
Just plain incandescents
Personally, I wouldn't bother with the LED bulbs in those year Accords, I feel as though the lighting is just uneven and looks odd when compared to the AC/radio/etc controls. You should be able to swing by a local AutoZone or Advanced Auto (or similar) and pick up direct replacement bulbs for those two.
The actual swap isn't too bad to get the cluster out - just take your time and save all the screws!
Old Sep 10, 2012 | 12:10 AM
Thank you all again Especially The Muffin Man!! Nothing like being able to "talk" to people who actually know what they are talking about. Love it!!
hondafitdad
Honda Fit
Jun 17, 2017 05:01 AM
Woodstock1969
Jul 21, 2016 04:25 AM
Otis B. Firefly
Jul 31, 2014 08:22 PM
PJM
Apr 12, 2012 01:42 PM
