Vtec oil leak quick question....
Old Aug 25, 2012 | 08:47 AM
eurochoi's Avatar
Default Vtec oil leak quick question....
I don't usually get up in RPMs much, mainly because I try to get the best MPG possible. But this morning I was feeling a bit "saucy" and did so on the way to fill up the tank. I noticed that there was more than usual oil on the top/front of the transmission. I have been trying to figure out where the small amount of oil was coming from for a little bit now.
I degreased the engine about a week or two ago to try and see where it's coming from. The bottom of the distributor is dry from what I can tell.
Is it valid logic to believe that after Vtec is engaged it could push more oil out than when it isn't engaged?
Vehicle: 96 Civic EX D16Y8 Auto
Old Aug 25, 2012 | 09:02 AM
ScareCrower's Avatar
Default Re: Vtec oil leak quick question....
Might be your head gasket i think.
Old Aug 25, 2012 | 09:05 AM
Hidenplanvew's Avatar
Possible leak from the Vtec solinoid, or bottom of the dizzy, valve cover gasket or cam seal can cause this to happen.. You can ge an oil dye from autoparts stores as a kit and that will show you where its comming from.
Old Aug 25, 2012 | 09:42 AM
eurochoi's Avatar
Yeah, somehow, through all of the rambling I did above, I did not put that I thought it may be the Vtec solenoid.....Hopefully it isn't coming from the head gasket though.
Old Aug 25, 2012 | 10:52 AM
JuggerNaut-CTR's Avatar
cam seal is on the other side of the motor, oil cant get on the trans from there
Old Sep 12, 2012 | 02:27 PM
eurochoi's Avatar
Replaced the dizzy oring today. I'll watch the area more but this is what I found. I cut it to get it off, but there was a bit of mushrooming of the o-ring.
Old Sep 12, 2012 | 02:38 PM
eurochoi's Avatar
By the way, for the vtec solenoid gasket it would be number 11, correct?
http://www.hondaautomotiveparts.com/...EAD+%28VTEC%29
Old Sep 12, 2012 | 07:59 PM
newbie007's Avatar
yes number 11, and also there is another gasket as the vtec solenoid top portion comes off the bottom half.
i had the same type of leak, i changed both these and now it doesn't leak anymore.
good luck.
Old Sep 13, 2012 | 03:45 AM
eurochoi's Avatar
It's hard to see the other one but, from what I can tell it looks like this one?
http://www.amazon.com/OES-Genuine-Solenoid-Gasket-select/dp/B001G7KUB0/ref=sr_1_1?ie=UTF8&qid=1347536652&sr=8-1&keywords=vtec+solenoid+gasket http://www.amazon.com/OES-Genuine-Solenoid-Gasket-select/dp/B001G7KUB0/ref=sr_1_1?ie=UTF8&qid=1347536652&sr=8-1&keywords=vtec+solenoid+gasket
Old Sep 13, 2012 | 04:56 AM
newbie007's Avatar
the one you have there has a mesh the one i got from dealer doesn't, it still worked though.
Old Sep 13, 2012 | 06:09 AM
eurochoi's Avatar
Thanks, upon further inspection, it looks like the one I was showing was for the previous generation.
Old Sep 13, 2012 | 07:11 AM
DontH8VA's Avatar
Hows everyone im new here but id def say the vtec solenoid gasket would be the quickest cheapest start
Old Sep 13, 2012 | 07:16 AM
DontH8VA's Avatar
Also just got to thinking check around the distributer if the seal on the cam on that side goes bad can get a leak from that side also just a thought
hardrock2401
15
Jun 18, 2023 04:53 PM
Travlash
13
Apr 29, 2015 07:58 PM
LoGaN-VanG
13
Jan 12, 2014 04:40 PM
NJ-JDM
Oct 23, 2013 02:54 PM
Busta16
Jun 17, 2010 12:59 PM
