92 Civic LX D15b/D15b8 Questions
Old Aug 24, 2012 | 11:45 AM
riZe`'s Avatar
Default 92 Civic LX D15b/D15b8 Questions
Hello all, I swapped in a D15B block with a D15b8 head (needed a engine asap and someone was selling it) and I've been having a few problems... It has all of the B7 things such as intake manifold, exhaust manifold, sensors and ECU.
1. What do I set the timing at? 12 or 16? d15b8 calls for 12 while the d15b calls for 16.
2. There is power loss through out the rpm range, just not a constant power, kind of kicks back a little.
3. On cold idle it idles rough.. First start ups = low rpm and sometimes even stalling.. I can't drive off right away because I have to rev it for a second or else it will just bog down. Also the RPM is at 650 at cold idle to warm idle..
It's a 5spd with no mods and I just replaced plug, wires, cap and rotor... Compression test on engine says 210psi on each cylinder
Old Aug 25, 2012 | 09:46 AM
riZe`'s Avatar
Default Re: 92 Civic LX D15b/D15b8 Questions
Bump?
jlk16188
Sep 14, 2013 12:45 PM
AustinRoyce
Jun 9, 2013 01:03 PM
fragmare
Oct 2, 2012 04:02 PM
austinkli
Jan 3, 2008 09:51 AM
passingthrough
Mar 27, 2004 10:32 PM
