Brake light comin on even when the parking brake is down...
Old Oct 16, 2002 | 09:41 AM
rockwilda's Avatar
Default Brake light comin on even when the parking brake is down...
i started my car this morning and drove it to a friend's house and i noticed everytime i stopped at a stop sign and began accelerating the "brake" light would light up... but it would go off when i tapped the brakes. i checked all my fluids when i got to my friend's house. and this only happens when i start from a dead stop,after i tap the brake and the light goes off, it doesn't come back on until i stop the car again.
anything guys?
Old Oct 16, 2002 | 09:43 AM
Austin's Avatar
Default Re: Brake light comin on even when the parking brake is down... (zyg)
You need some brake fluid.
Yepo
Old Oct 16, 2002 | 09:49 AM
yoshi234's Avatar
I shoot brides
Default Re: Brake light comin on even when the parking brake is down... (Austin)
Yepo
yaya!
Old Oct 16, 2002 | 09:53 AM
Chris's Avatar
Also a good time to check your front pads.
werd.
Fluid can be low.. but it also indicates you pads might be low, causing more fluid being required to get the pad in contact with the rotor.
Be careful because adding fluid, then later changing the pads will cause a overflow!!!!
Old Oct 16, 2002 | 09:54 AM
mstewar's Avatar
Default Re: Brake light comin on even when the parking brake is down... (rockwilda)
could be the often defective reservoir cap, but check the fluid level first.. it's probably low, based on what you described..
edit: didn't think about the pads possibility.. hmm..
[Modified by mstewar, 1:55 PM 10/16/2002]
Dave-ROR's Avatar
Default Re: Brake light comin on even when the parking brake is down... (Chris)
bah, it's just paint.
alos the cap on the resovoir might have gone bad. seems somewhat common.
Old Oct 16, 2002 | 10:05 AM
Willard's Avatar
another idea is to check to see if your brake lights are working.
my other car has the door dinger ring and flashes the brake light when the rear bulbs are out.
Old Oct 16, 2002 | 10:15 AM
mstewar's Avatar
wouldn't the light still be on, even with a new cap, if they needed fluid?
i doubt any would admit it, and hopefully they were able to return the part!
Old Oct 16, 2002 | 10:18 AM
Vu's Avatar
Vu
Default Re: Brake light comin on even when the parking brake is down... (mstewar)
Mines come on everytime it gets cold outside. In the morning when it's cold it comes on, drive it around for awhile, it goes off. Start it in the afternoon when it's a little warmer and it doesn't come on
Old Oct 16, 2002 | 12:08 PM
Champ R's Avatar
Default Re: Brake light comin on even when the parking brake is down... (Vu)
That happened to me an hour ago when i was driving. Its like 40 degrees outside here and i went for a drive and the brake light was on. Im like wtf since this has never happened. I thought it was something with the parking brake because it would kinda flicker when i pulled up and then down. So i went into a store for a bit, came out, started up the car and it was gone.
Old Oct 16, 2002 | 12:09 PM
mstewar's Avatar
same thing mine was doing.. new cap stopped the problem..
Thatssojdm
Feb 26, 2008 08:05 AM
Pabs626
Dec 9, 2007 05:02 PM
RenzoDaPlayboi
Apr 24, 2005 12:48 PM
ham_yorkwind
Apr 10, 2005 07:43 PM
Understeer
Dec 1, 2003 09:40 PM
