which hand do you use???
i'd like to throw this out there to see how many of us goofy asses there are. so the question is, which hand is your dominate hand, and which is your TIG torch hand?
for instance, i am a righty. i write with that hand, bowl, shoot, play baseball, everything with that hand. however, i hold my tig torch in my left hand
and...............GO!
Who is Mr Robot?
I'm weird. I write right handed, throw a ball left handed, hit left handed, catch left handed. Hold my tig torch with either hand depending on what I'm doing but mostly hold it left handed, since your dominate hand is for fine motor skills that's usually the hand you feed filler with
I weld equally good with both hands. Pretty much impossible to do my job otherwise. When i learned to weld i only did it once in a while so i would always forget which hand i held the torch in so i just used both from the beginning.
