Lighting HID/Xenon kits, Retrofits and Associated Topics
Dome Light bright when switched to Door, but not bright when switched to On, flickers
Old Aug 23, 2012 | 07:25 PM
mikekh10a's Avatar
Default Dome Light bright when switched to Door, but not bright when switched to On, flickers
So here's the situation
  1. Switching it to "Door", it will be satisfactorily bright
  2. Switching it to "On", it won't be nearly as bright, and flickers on and off
It's not just the bulb, I tried 2 different style LED bulbs, and the regular bulb..same problem.
It's a 1998 Honda Civic CX Hatchback if that matters.
Old Aug 23, 2012 | 10:30 PM
EJC206's Avatar
Default Re: Dome Light bright when switched to Door, but not bright when switched to On, flic
maybe your wiring is messed up somewhere. but it couuld be when it is on its constantly needing power and when its on door it only uses when door is open but idk lol
Old Aug 28, 2012 | 08:36 AM
Striker325's Avatar
It sounds to me that it is going to be the "wear" on the switch that gives you a choice of (on,door,off)
Old Sep 3, 2012 | 03:49 PM
Advan_japan's Avatar
sounds like a wire issue. Check connections for possible wear/corrosion. I had a similar problem and it was a worn out wire that was barley in tact.
Kathyle3
Oct 23, 2016 06:21 PM
GarySeven123
Feb 16, 2013 05:21 AM
curtie94
Mar 18, 2011 07:07 PM
lovemyintegra1
Jul 16, 2007 11:47 PM
Chiller20
Dec 26, 2002 06:29 PM
